REview of Mag and TL on Jetmaniac motor
Sorry it took me so long to do this review. I waited on a few parts from summit to get here for my total loss. Josh and Gil helped me with the build. Gil helped me figure out my problem and also timed my ski. Thanks guys , big time.
. first Ill start with the mag pump. My setup is a 144 setback mag pump with a 9/15 hooker. Dual cooling. Protec 50 extended nozzle. All I can say is WOW! The hook up is unreal. There is no lag at all. You can actually feel the thrust from the pump. Making turns and catching a setup wake seems a little harder. For one when you attempt to make a sharp turn the pump seems to push the water out a lot faster, which makes the back end very loose. when you make a setup wake, you have to time the wave a little better. In my opinion the stock pump felt like it needed to load up before pushing it out. The mag seems to thrust whatever water is passing through faster so no hesitation. I hope this makes sense.
. the total loss system took me a little time to setup but with the picture instructions from Josh and the help from gil it wasent so bad. The spark from the Total loss is amazing. My ski never felt so strong. A half push of the start button and she fires up. The ski feels like it runs to its full potiental now. I still need to do more tuning but it hits harder than stock msd enhancer with bad tuning.
All together I would say this is a amazing setup. Now I need a Aftermarket hull. If anyone would ask my opinion on whether or not to purchase these two parts. I would say hell yes.I know a lot of people would ask ( which one would you buy first?) I couldnt chose between the 2 because they seems to do great on different levels. I also got a 3gl jaz tank from Brian at thrust. Really easy to install and looks killer.
A little action pic from today.
picture of the new tank and total loss
