Custom/Hybrid Superfreak Pump Install issues...Need tips/advice
I started my SF build this weekend. Wanted get the pump/midshaft/engine aligned but ran into a road block very quick.
I called jetmaniac on Saturday and he walked me through the steps and gave me some great pointers. I tried to get the pump to line up with the pump bolt inserts, but I just can't get the last 2-4mm or so. Very frustrating.
This is my first pump alignment so I am not sure how to tackle the problem. The pump shoe and pump inserts seem to be installed very well.
I am not sure if I need to do one of the following or a combination of sorts:
1. Grind the soft/flappy part of the pump seal. The part that goes up against the pump shoe.
Does anyone do this or will this cause cavitation issues or any other issues?
It seems that if I can grind the flap off, the pump will line up just fine.
2. Grind the pump shoe
3. Grind the wear ring near the front where it meets the pump seal between the wear ring brackets.
4. Grind some of the hull down, near the pump shoe. Hoping that the pump would slide forward a tad to drop the bolts in.
4. Reinstall new inserts to get them more forward
Here are some pics. I will try to tell the story as best as I can.
Pics of the pump shoe and how it's installed.
pump alignment 025.jpgpump alignment 026.jpgpump alignment 027.jpgpump alignment 028.jpgpump alignment 029.jpgpump alignment 031.jpgpump alignment 046.jpgpump alignment 047.jpgpump alignment 048.jpg
Crab
thanks darin...noswad!
Seattle
Whoow, hold off on grinding anything until you see if the pump shoe is square to the pump. With the pump inserted and lined up and centered, the pump seal off, you should be able to see how close it is all the way around.
1. Make sure that the top of the pump seal is ground flat. You need to take some material off.
2. You may need to grind a little bit off the pump in that area, as well.
3. Use a ratched strap around the pump and the front of the hull. Basically you're using the strap to force the pump forward. Makes life a lot easier.
4. The rear two inserts may be off a little bit. They were on mine. I needed to open up the holes in the reduction nozzle tabs a little.
Pics of the pump seal where I ground down some spots for fitment. When I talked to JM, He said that I may need to grind down the pump seal to metal if I heard him correctly.
I learn best visually and kinesthetically, when it comes to things like this. Plus I was in a warehouse and I couldn't hear JM that great.
I hope I got it right but I am afraid that I didn't. He explained that I may need to grind the pump seal down a bit( the part that would touch the part of the hull.
pump alignment 015.jpgpump alignment 018.jpgpump alignment 019.jpgpump alignment 023.jpgpump alignment 032.jpgpump alignment 033.jpgpump alignment 034.jpgpump alignment 035.jpgpump alignment 036.jpgpump alignment 037.jpg
Ratched strap, bro. My 140 mag desperately needed it.
My 148 mag could do without it.
Great points...I will def use the ratcheting strap idea instead of the clamps.
Is it ok if I just open up the holes in the reduction nozzles and the wear ring?
Is it a no-no opening the wear ring bracket holes up since I have the dowels out?
Would flat washer and then a lock washer do the trick?
That's a great idea...the clamps were a pain to get them to pull the pump closer.
R u guys attaching the hook to the reduction nozzle or using a soft-strap type ratchet?
I put a hook on the reduction nozzle tabs.
I wouldn't open the wear ring holes - but only because in my experience, those were dead on.
Crab
Seattle
Another thing I did, bolt it up snug so it will stay and smack the reduction nozzle with a rubber hammer if needed to get the driveshaft centered, it should move then stay where you want if done right.
Watty
Random Performance
Australia
If you are talking about getting the pump pushed up against the pump shoe enough...here's what I do.
- Flip the hull (you've done this)
- Make sure the pump will fit up ok without the pump seal
- Fit the pump seal, fit pump
- Get some large philips head screw drivers that are slightly smaller than the 8mm pump inserts
- Place a screw driver through the reduction nozzle mounting tabs and into the insert holes on either side
- Lever the pump forward with both screw drivers until front holes line up with hull inserts
- Have a buddy tighten them up while you continue to hold the screw drivers/pump in place
Once the front bolts are done up, the pump shouldn't move and the rear holes will be aligned as well. You may have to do again if you need to shim the pump, but at least you know how.
You won't damage the threads in the hull if you use large screw drivers. Tight pumps are a pain, but they are better for performance etc.
I am lovin these tips...Please chime in if you have any good pointers
JM says that once you get the pump lined up and bolted down, you can always leave the wear ring and pump seal bolted up by pulling the long bolts out.
Changing the impeller for example...
Unless of course, you need to work on those parts...
KTM434
Jamie FN Hickey
Palm Coast FL
Watty maybe in your experience you haven't damaged the threads on the inserts by prying on them with screw drivers but I wouldn't advise anyone to do that. Not everybody knows how much prying pressure is safe. If the pump is hard enough to move forward then I wouldn't want to put all that stress on the threads especially when it's the pump inserts. Using a dead blow hammer will help get the pump where it needs to be if the inserts are properly located and it's just hard getting the pump to line up and push forward. If the hull inserts are located too far forward (I didn't have this problem on mine) you may need to enlarge the holes in the wear ring or reduction nozzle flanges (depending which ones don't line up) if the ratchet strap doesn't do the trick. Just make sure there is enough pressure on the pump seal so it still seals tightly enough to avoid cavitation. Any gaps or uneven transitions between pump shoe/pump seal/wear ring can be filled with silicone or similar. I had to grind my pump seal like you did and also did a little grinding on the wear ring in the same area (the raised flanges) and maybe the pump too just so I knew they wouldn't be tightened into the hull causing extra stress on the hull and inserts and so I knew the pump flanges would sit flat on the hull.
i found out that the freak wont cavitate if the pump seal is very loose. on mine, the 2 wear ring bolts fell out and the 2 nozzle bolts were very loose. the whole pump was about to fall out and it has no effect on performance. luckily i saw it before the mag pump ended up in davy jones locker. the pump seal was rattling around in there like a BB in a bandaid box and no cavitation. i was impressed.
Watty
Random Performance
Australia
That's why you dry fit the pump first without the seal, you can see what you're working with. Also, common sense prevails when using the method I suggested. You don't want to have to swing off the screw drivers to push the pump in. Obviously if there is a lot of resistance, it's not going any further. If someone can't use some common sense when fitting a pump and know how much pressure is safe, what's stopping them from cross threading a pump bolt and just winding that sucker home?!
I would have done this to 20+ ski's and have NEVER damaged a thread, or even made it so the pump bolt is tough to screw in. You will find you have to do the same to any Foot Rocket as well. They go in nice and tight using the screw driver method, or, you can leave the pump seal out and silicone seal the area with great results. The only problem with this method is if you have to pull the pump, you need to clean all the sealant off and start again.
