teton
tetongravity.com
- Washington DC
is that an 08 style bottom?
did you fill the air holes in the hood or is it a diff version from the black? I have only seen the rectangle holes in the back.
Black hood is the Xscream hood built by superfreak, it is going on my surf bomber hull (will help lighten up my wet foam heavy hull). Killer lines and design on this hood are by Pat Bogart.
Green hood is a superfreak designed hood for the superfreak hull, this hull has the handlepole bracket mounting area lowered approx 1.5" from stock. The hull, nosepiece, and hood are designed together to be even lower to the water.
That thing will be so cool! What color turf will you use, Chris?
that integrated FFH is so freaking sexy! are those a Tem design foothold??
