When the ski was stock there was no vibration (obviously) this winter I built it up a bit (ada head, dry pipe, enhancer, 14/18concord, wwc etc.) after riding it this spring it seems to have a mild driveline vibration on the mid range. When I yanked the motor I carefully removed each set of shims, taped them together and bolted them back down to the mounts, nothing has changed except the above mentioned stuff. What could be causing this? Maybe slight cavitation? I dont think the exhaust is hitting the hull...ideas?
