- Carlsbad, CA
Okay on a head mounted pipe I agree...if you are running a B-Pipe you will not have any issues.
JC
JC
IM not crazy, I just dont like to crack expensive parts.
http://x-h2o.com/showthread.php?t=17774&highlight=cracked+cylinder
http://x-h2o.com/showthread.php?t=4660&highlight=cracked+cylinder
http://x-h2o.com/showthread.php?t=572&highlight=cracked+cylinder
there are lots more.
You might run forever with no problem, but I wouldn't risk it.
I think of the girdle as cheap insurance.
EDIT:
you are doing the crayfish shuffle there arent you?
haha
folks have cracked them with B pipes too, FYI
Im just trying to save the guy some hassles, get a girdled head if you want more compression on a 61x cylinder, regardless of what pipe.
Whats one of the better heads to get?
dude, i posted a link where a cylinder cracked with a B pipe.
a girdled head is better. simple enough.
Ive still got that cylinder from Surfguy45.
I havent done anything to it yet.
My plan, is to epoxy/JB weld it, and girdle it, and see how long it runs like that.
Hardly.
you said the smart thing to do would be to cut the head, I argue that would be the "cheap" thing to do.
The smart thing to do would be the girdled head.
I know lots of folks run milled heads without problems, maybe they are lucky, maybe they have better cylinders, but neither of those things makes them smarter.
for you to sit here and try to convince a 'newbie' that he wont break is simply dumb.
how about you offer to trade him cylinders if his ever does break?
EDIT:
I never said WILL crack, I said greater risk of cracking.
you should read more, and argue less.[/quote]
Matt's right. Cylinders w/stock compression and pipes crack sometimes. I wouldn't do any mods w/o a girdled head.
Hey nightrider,
this guy didnt think he needed a girdle either, with a B pipe.
http://x-h2o.com/showthread.php?t=4687
Hey nightrider,
We're cool.
I guess until you experience it yourself you can only offer your real world experiences. I have never (personally..obviously it does happen) seen a cylinder crack on a ski with only a mild compression bump and a b-pipe.
I did read back through the posts and I did miss some key points, my apologies for that.
Just for the record...I never felt like we were arguing. I just wanted to let people know that my "real world" experience has been that 180 psi without a girdle kit has worked for me for over 5 years. Just the other side if you will.
JC
