Superjet "free" mods list - add yours!
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
Hi all,
I just got a RN and was thinking that maybe a list of "free mods" (that do not require purchase of aftermarket parts, only some hardware, tools and/or chemicals) would be nice for all those who spent all their funds on the ski and have no $$$ to buy aftermarket stuff immediately:loser:. Please keep it LOW BUDGET. I would divide this into 3-4 categories (hull, steering+handling, engine (intake, exhaust, electrical, pump, other?) for easy reference. Please add your VERIFIED/TESTED idea:
I. HULL
- shorten oem pole (cut it with saw/ grinder) - cost: time
- OEM chinpad weight removal and strenghtening - cost: time, metal plate, some sponge type material, small piece of hydroturf
II. Steering
- quick steer mod at nozzle (extend OEM mounting of bolt) - cost: time, metal plate
- changing the bolt position at the steering plate
III. PUMP
- getting rid off the OEM fountain that sprays your A$$ while riding - cost: time, plate to cover OEM holes
- blueprinting (smoothing out the pump area from factory castings) - cost: time, power tool, grinding hardware
- Nozzle boring (better low end punch) - cost: time, 15-25 usd in machine shop, or do it yourself.
IV. ENGINE
- removal of 1-2 filter screens in OEM intake (better airflow) - cost: time
- engine porting - cost: time, power tool, griding hardware, top end gasket kit
R
ridethelip
Guest
IV. ENGINE
And Then..........
Cost:Time and money after you roll the ski while riding and it devours that random bolt bouncing around in the hull because the screen was removed.
Sospikey
Trying to get upside down
Sweden
IV. ENGINE
And Then..........
Uhm...there are 3 to start with. Removing 1 or 2 could MAYBE allow a M2 or M3 bolt through, but that's pushing it. Riding WITHOUT screens, now that's another story.
Waternut
Customizing addict
Macon, GA
I would consider porting a fairly risky "free mod".
I would also say that one of the best free mod you're going to get is makig sure your carb is tuned properly.
Polish jet pilot
Warsaw, Poland
Great! Keep them coming!
About the ball joint at the nozzle: I understand why you would move it closer to nozzle, but not sure why you can buy "extenders" that actually take the ball joint further from the nozzle... do they do the same job? And one costs, the other doesn't?
The extenders for the nozzle ball joint seem to do the opposite of what you want for freestyle.
When you move the ball closer to the nozzle, drill the hole close to the front (towards the nose of the ski) of the nozzle arm to minimize the adjustment needed to the steering cable.
I. HULL
reinforce, tow loops, hood straps, seal front holes in hood
II. Steering
handlepole limiting rope, pad on hood to protect handlepole from coming down hard
IV. ENGINE
flush kit
