SXIPro
JM781 Big Bore
- Here on the 'X' mostly
I actually found my Kawi much scarier/squirrelier on the top end than my SJ. The Yami never tries to toss me.
Maybe I'm weird. :Banane13:
i went from a 550 to 650 to 750 to sj.......the sj handles a million times better than all of those and is amazing in the surf. i had no prob getting on the sj and getting used to it. i dont see any problem, ride it around for a while and ull love the way it turns. the sj doesnt even seem quirly at all compared to the 750, and the kawi would ALWAYS toss me, so im not sure what ur rtalkgin about lol.
I have a bpipe with the a sj mod chamber in my fx1 and it rips just make sure you mod you cdi without the csi mod the pipeis just eye candyBetween the x community, anything can be found out. You guys know it all!
Im just looking over my fx-1 trying to get a few parts cleaned up/replaced and that factory exhaust just looks so puny compared to the pics i see around here.
Going fast in a straight line is for couches. :ugh:
I recently put a B-pipe in my wifes sj. I could'nt believe the improvement in throttle response & bottom end. (tuned for surf). It pisses me off cause I have stock exhaust in my sj still. Saving up.
i thought that was to help straighten out the ride due to prop rotation? and as a sacrificial piece?The wandering at WOT is actually called seeking. All stand-up skis do it after about 46-48 mph. It's just because the hull is so narrow. If you look at the gear case on an outboard, they have an adjustable direction correcting tab under the stabilizer fin. It's to true up the straight line when at WOT because most of the hull is out of the water and you're left with that little narrow gear case for the control. I would think a ride plate with fins would help to counter that with your ski but not sure how they would affect the freestylin.
:haha:No kidding. :wink:How'd that one happen??? The wife gets the brap?
In my experience with my SN, you try to turn flat and you'll get thrown off. When I take tight turns I almost have to lean till I touch.The superjet takes a little getting used too. It turns flat unlike the kawi's which you can really dig and carve effortlessly. The superjet can dig to though. Just takes some work. Put alot of pressure on the foot on the side of the boat the same as the direction you want to turn and it'll stay hooked up. (left turn = press down left foot) As for the problems at WOT, Sometimes my SJ hucks me, but usually when it starts to chine walk I can keep it under control as long as I stay on the throttle. Once you let off the throttle the boats gonna vere off in another direction and you're going to go straight. Once you get used to it you'll know what all the hype is about though.
I know, it sux, but her stock exhaust corroded and was leaking, and mine was still o.k. I'll have a pipe this season.How'd that one happen??? The wife gets the brap?
never heard that before...I have always heard and used the term "chine walking" in reference to skis and big powerboats
Regardless of which parts are used, the Hammer will still be somewhat difficult to control at very high speeds. Even the best stock SX hulls will begin to "seek" at speeds over 46 mph. "Seeking" is the point at which the handlebars no longer control the true direction that the boat is traveling in. Safe steering beyond this speed is done with body english and proper weight transfer. While hull truing may improve this handling situation, it cannot eliminate it.
