that home made hillbilly pole is the entire problem. the geometry is all wrong. the steering cable in the center is all wrong and puts the cable at a rotten binding angle. the turn plate could be flipped over if you counter sink the bar clamp holes on the flat side. ive used kawi turn plates on yamaha by doing this. the bearings still roll even tho the machining wont match up. then the ball will be farther out, using the 3 holes and that'll make it a quick steer. unfortunatly that will put the cable on an even worse bind. the cable should be running down the right side, not in the middle. right now the ball is way too close to center and not throwing the cable enough. who ever designed that pole has no business making anything.
