- Lemont, Il
My superjet takes on a lot of water when i submarine. is there any hood mod i can do to reduce water intake?
How do you seal them up? would that restrict air flow and the motor wont run as good?You can seal up the holes on the front of the hood. Besides that, not much you can do.
Mine breathed fine when I experimented with it. Put some duct tape over it to see if it improves before you seal it up with fiberglass or something permanent. Also ensure that your hood seal is in good condition.
