Superjet Hull Measurements
Does anyone have a (pre-96) superjet laying around they could take some measurements of?
My pump area was modified by the previous owner and I am running into an issue where my rideplate high-centers on my pump.
Can someone please tell me the correct distance from the pump mounting surface to the rideplate mounting surface?
Also, the ride plate should be flush with the hull bottom, correct?
Thanks!
This?
Sent from my SM-G970U using Tapatalk
Yes thank you! what would you say it measures? Hard to tell from the angle.
Copy the image and square a line in Google draw or something along the bottom edge. Ski is on the ground and I couldn't get any lower. It's like 4 5/8?
