Big tip a buddy told me that helped a lot was to hold the bar like I'm doing a bench press, especially at higher speeds. Keep your knees bent some more and apply forward weight/pressure. Don't feel like you're just riding the ski, feel like you're forcing it where to go and you know it's just gonna do it. In my earlier days I rode with one foot in the front corner and the other foot brought up mid-tray. As I progressed, I was able to shift my feet/weight thoughtlessly and keep the ski positioned how I wanted it, depending on speed and conditions. Over time it will come naturally and you won't strain your knees or back as much in the process.
Another thing that helped a lot was to add shims (washers) under the rear bolts of the plate. A little goes a long way! As I progressed, I took them out because it made it harder to do good wake jumps. The Jet Dynamics ride plate (extended version for my 215# self) was a lot more nimble in the turns than my previous Worx Dominator extended plate, and just as good or better at stabilizing at speed in a straight line.
