how do you get the pump off? i already took the ride plate off the hoses and then i took off the steering rod and the 4 bolts that hold the pump on but how to get it off am i missing something?
beachjunkey said:There might be two .25" "dowels" on the pump or nozzle that goes up into the hull. You'll have to wiggle the assembly up and down a little while pulling out or pry it down a bit.
