- Timmins
Hi guys,
Just a few questions in regards to a few modifications I will be undertaking.
1- I would like to modify my stock handle by cutting 4" shorter than its original length. I'm guessing the easiest way to do this is by removing the rivets at the base of the handle near the mounting bracket. The pole should probably be cut from the end that is closest to the nose of the ski as well right? What is the best way to cut this? A band saw is what I was thinking. Any pictures someone may have would help.
2-I'm installing a new nose cover that will no longer have the original holes as the stock nose piece. Do I need to ensure that I receive air from another inlet???? Or can I simply run it without any holes feeding air to the engine? Kind of skeptical about that.
3-I have installed the msd enhancer should I be running a heat sensor with it? Is it even worth it?? I don't believe my aftermarket head will allow this.
4-I'm installing frogskins on the underside of the hood has anyone ever done this? There is a plastic bracket that is riveted to the u/s of the hull which hold a rubber pipe with a pipe clamp. In order to install the frogskins I would have to cut this plastic pipe flush as the bracket cannot be takes out of the hull since there is maneuverability restrictions. Will I no longer need the use for those two pipes?
