- Granbury, TX
Your midshaft bearing is most likely worn out and needs to be replaced. The engine side coupler threads on to the crankshaft and I promise you it isn't moving from its original position. The midshaft is press fit into the midshaft bearing and the bearing ID or midshaft OD might be worn enough to not allow the shaft to stay in place. The other thing to check would be your motor mounts... You usually shouldn't see your midshaft/coupler get pushed back that far unless you are majorly flopping the ski enough to let the motor move that much in its mounts.
