Vumad
Super Hero, with a cape!
- St. Pete, FL
My build thread is in my sig. I use my SJ for surf, flat and racing. It's not set up for any one thing. I just changed it from all stock to fully limited.
I have a 2004 SJ stock motor, FPP pipe SJ manifold Kawi headpipe limited SJ chamber (top and middle closed, bottom open, can't adjust it), girdled head 180 psi, stock carbs jetted to spec, dual stage carbon reeds, reed stuffers, lightened stock flywheel, jetwork blue FCV (most open setting), MSD enhancer rev set at 8000, stator I think is still in stock position right about middle of available adjustment, various unrelated handling mods.
Cooling was as follows. Pump to manifold. Front line off head Tee to stinger. Back line on head to bottom of pipe. Front of pipe line connected to the other line from the head with a T (only one ADA pisser). Boat moved tons of water, threw it like 5' off the boat. Boat ran great through the RPM, 48mph on GPS in 1/4-1/2 mi drags, plugs nice brown color, no issues. No tach (have one now) so have GPS speed but no RPM.
Next ride I set up a small bouy course and got on it, maybe 1/4 mile track, about 4 laps. Came in to check, vapor rolled off the head, head pipe and chamber, not off waterbox. Hard sizzle on the 3 bolts that hold the head pipe to the manifold. No other sizzle.
Too hot, today I changed from 1 pisser to 2. Same cooling except the 2 lines don't rejoin, they get their own pissers. Water now thrown about 2-2.5' from boat from each pisser. Only rode a short bit, noted exhaust leak, I assume the other day I either split a weld or melted the coupler.
Everyone I have spoke to says single cooling should be enough for my boat. Jetmaniac, Xscream, various others, single cooling should be sufficient. What could be wrong with my boat? I am going to pull the stuff and find the exhaust leak. Hoping to resolve the issue while everything is out.
Any ideas? Is single cooling sufficient? Or is it only because most people are freeriders and single cooling is insufficient for extended WOT and racing. If I go to dual, should I do dual cooling or parallel. Help is appreciated. Probably going to end up switching to dual cooling but I don't want to mask a problem or over cool and damage something important.
Thanks
Thanks
