Gainera2582
Power and Agility
- Lake Saint Clair, Michigan
Will the connector from the store fit the spark plug boot I have? It seems this one is different than the automotive and msd ones(more like a spring).
Have you checked the little tiny bucket filters in the carbs? - sounds like one is blocked to me and not allowing enough fuel into one of the cylinders - the other is trying to 'carry' the starving one.. you can hear it 'hardening off' in your video..
My ski has done this twice in the past - same thing both times, sounded and behaved just like yours - I run a JSS inline gas filter now.
Pull the carbs and have a look.. they get blocked up with fluff, hair and crap out of gas stations..
totallly off topic, but what pisser outlet are u running?going to check things when I wake up. Keep the ideas coming!!!!
Ok, so I actually got motivated enough to work on it. Tried starting it, heard a buzz and then nothing. So I took the start stop switch apart, looked like their was some moisture in there, wd 40ed everything, wiped it up, dielectric grease on everything, sealed back up and it started. Problem 1 solved.
Problem #2 checked spark again, and I still get a fat blue consistent spark on the rear cylinder but nothing on the front cylinder( i saw it spark once). Now, i have cut this wire back before, tested to make sure it had spark before putting the boot on, and sure enough it had spark.
Any suggestions?
Thanks,
Aaron
