Superjet scupper leaking
Took the ski out today and found that it was taking on a good bit of water. When I looked inside I could see a steady stream of water coming in the scupper. Is there a way to fix this or should I buy a new scupper.
Tuscaloosa, AL
What scupper is it? On my old 24/7 scupper I would add a little layer of grease where the flap met the alum trim. this would make it kinda sticky, once this stopped, would get a new flap. Also if it has an alum plate that screws to the top, you could try loosening the screws, sometimes when tightened too much it will force the flap away from the lip. My RRP scupper has leaked since day one on my edge.
It is a x scream scupper and I will try to mess with the screws and see if that works thank you
