Philip Clemmons
Owner, P&P Performance
- Richmond, Va
Wondering who has personal experience with this one................
I have a 701 (62T), b-pipe, advent, 35 cc domes, and the dual 48 full spec carbs with billet manifold and 3 stage carbon reeds. The ski rips pretty good, but is not as crisp right off idle as I would like. Mid range is awesome and hard to hold on to. I rode a single 48 Riva powerbomb ski with the same pipe and head set up and it seemed to hit harder off idle, but not in the mid to high (but needed some tuning to be fair).
I have been told my 48s are too much for a stock motor-I have also had several people say its the hardest hitting SJ they have ridden.............I understand airflow and carbs and it stands to reason that the higher airspeed of a single would help bottom and mid on this setup, but I would need at least a manifold and possibly some good reeds/cages (v-force?) I am a little reluctant to change it, but would like to get more hit off the bottom. This is a surf/freestyle ski only and top end is not an issue............
Any chance the Riva works better than the Full Spec, or is it a single vs dual issue?
Has anyone done any testing or swapping under these conditions and come to a reasonable conclusion?
