z00m
UK X-H20
- UK West midlands
Hi i want to remove the crank case drain on my sx 650 before it fails , my question is , with the exhaust off can it be blocked off with out removing the motor ??
Mick
Mick
try it and find out =D
It's a tight fit, but you can do it. Just be careful not to drop the o-rings.
If its the same as a 750 I just tapped for pipe plugs no kit required.
Mark44
Yes it sounds the same, I think I tapped the holes for a 1/8" NPT pipe plug it's been a very long time since I have messed with a Kawi motor. It only took a few minutes to do.
Mark44
