SX-R 800 Bilge Pump Help
djkorn1
kidkornfilms
Cleveland Ohio
Has any one tried the blowsion bilge pump bracket?
http://www.blowsion.com/detail.asp?PRODUCT_ID=KASXAL440
Would that be better than mounting it where the tool kit goes?
Where do the bracket mount to?
No, it is not better. This keeps it from banging around...it works perfectly with the stock toolkit strap and a piece of turf under it. It will last FOREVER this way.
I'll keep saying it. Rulemate 750 is the BEST bilge for an SXR...and the Blowsion bracket will NOT work with it. Plus, why spend money you don't need to on brackets that break and switches that will burn out when you have a PERFECT mount for the Rulemate built into your ski where the toolkit is.
I run duel 1100 gph atwoods. They are awsome, cheap, and same size as the rule 500. They draw very little on the battery. We have 2 skis set up with them and have left them on for a week and still started. I have brackets I used but if I do it again I will just epoxy them to the bottom. We have run both the rotary switch and billet bar mount switch with zero issues.
