- buffalo ny
Long story short, I just brought this pro home and ran fine when picked up. Cleaned the carbs and installed a primer kit. Also fixed 2 of the broken plastic grommet caps on the ebox. reassembled everything and now it won't rev out and it backfires like crazy when you try to open the throttle. I rechecked the carbs and they seem good. Could it be an air leak on the carb gaskets? sbt sent me gaskets that didn't quite fit (had to cut the holes bigger).
