sxi pro porpoising
SXIPro
JM781 Big Bore
I had an extended Worx Dominator that I shimmed as well. I believe I had a Jet Dynamics Scoop grate, but can't quite remember. I sold my Pro quite a few years back. Thing that helped me the most was more tray time and to ride with my steering a tiny bit turned. If I kept it 100% straight it was a bucking bronco.
Agreed, Tray time is the best solution. I used to run a extended R&D 110mm plate. I now use a shortened and d cut stock plate. I also run a R&D grate that helps a ton in the corners and in chop
snowxr
V watch your daughters V
Waterford, MI
I had front sponsons, hull extensions, r&d ride plate and grate, and lots of weight under the engine and in the nose. Rock solid. I have an extra set of extensions if anyone is looking for their sxi pro.
