SXR 1100 Swap Help !!
Tuscaloosa, AL
Instead of pulling water from the T coming from your pump to manifold for stinger, I would "T" the line coming from the Head to the Head pipe. You want all your water pressure to be the same coming into the manifold. Or you can run a split system, where 1 line run water to the manifold and cylinder, and the other is dedicated just to the exhaust cooling.
do I need make holes for the water jacket in both the intake manifold/headpipe gasket, and the headpipe/chamber gasket ?
