- Prince George,BC
I have an 08 SXR it has a wetpipe on it so i have removed the factory temperature sensor and just siliconed the connection and electrical taped it also has the 6 degree timing advance . It also has a Bildge pump installed. I am just stating this to let you guy know about any changes i have done to the electrical system. Now to my problem. The machine runs fine out of water but as soon as i put it in the water it will run ok until about half throttle than it just falls on its face like it is going lean and i have to feather the throttle to get it back to shore. I have adjusted my highspeed screws out as much as 5 full turns and i still cannot get it to stop. Thats why it makes me think that its not a fuel issue even though it feels like it is running lean. Another thing that leads me to it being an electrical issue is that when i went to start it the other day the battery was dead and i just installed a new battery less than a month ago. Im wondering if anyone knows of issues that cause the battery to drain or if anyone has encountered somehting similar. Its almost like the tempeture sensor plug is making a connection causing it to go into a limp mode. Other mods that i have done inlcude vforce 3 reed novi 48 mill carbs, 27cc jsu head, and reed spacers i dont know if that is important i figured i would just let you guys know how she sits incase you think it could be a different issue. Thanks Alot!
