BTW: to give an answer, AC is the only one that bolts right up.
The replacement AC pole for the kawasaki.
Actually the UMI or the RRP will bolt right up with the proper bushings. They have been designed to run the SXR cable on the left side.
The AC or oem superjet pole (yamaha based) will need to be opened up to clear the steering cable.
You will need to change out your steering plate and chinpad unless you use the ac replacement pole.
OEM
Dales pole= good stuff. bolts right up.
AC Yami= the only pole I have ever heard of that NObody has broken
