SXR SXR mid range rattle
TimotaLT
Lake Rat
Lake Travis, TX
Last time I had mine apart I put silicon on the splines on the end of the shaft to the prop and helped for a while but came back after several rides but wasn't as loud for sure, mostly just noise when out of the water
Jersey
My 06 SXR did that, I had some work done on the pump and the guy put a small chunk of rubber, between the drive shaft and the end of the impeller, its been two years and I have not heard it since. How small is "a small of a piece of rubber" I dont know, I can find out.
djkorn1
kidkornfilms
Cleveland Ohio
stick an extra O ring on the end of your drive shaft to tighten it up....(or maybe the stock oring is gone???) They do break down after a while.
There SHOULD BE a good thick O RING at the end of your driveshaft in the prop is the point of my post. cheap easy fix.
Cannibal
Tasty Human
Summit Lake, WA
I had no idea there was supposed to be an o-ring down inside the impeller. I just pulled my nose seal and looked in there, sure enough, a nice flat o-ring. Guess I'll slap a new one of those in before I put this pump in.
Thanks!
