SXR starter problem
Starter does not work, battery charged, no click what so ever and there is power going into the starter but not sure about going out?! AHh any suggesttions?! we just got to havasu for S.B. and it died!!!
Shonuff
I've got the glow
Memphis
Disconnect the start/stop line in the hull and jump across the two leads with some needle nose pliers. If nothing happens, go to your battery connections.
Have you checked your battery yet to see if it's simply dead?
Proformance1
Liquid Insanity
New York Crew
Check the grounds also for even the littlest corosion at the battery. Wire brush or sand paper on terminals and cable ends.
