SXR Sxr takes on water while sitting in h2o
My 04 SXR is taking in water while just sittin in water and coming from raar ski. Anyone else have this
type of problem" if so what is the remedy? I have isolated the problem to the pump area. It takes on quite a bit. Of. Water not just a trickle. Any help wouldnappeciateda
there is a seal where the drive shaft come into the hull.... Id try that. Maybe pull the boat out of water and put on a stand. Then fill with a garden house and watch to see where the water comes from. Goodluck
So if understand correct, fill the engine compartment with water (enough to cover stock bilge) and serif water drains? Wher should I expect to see it come out? Or should I fill over the through hull seal and see if comes out driveshaft area?
icecoled007
Captain of this ship
Colorado
Mine still leaks a littlle.... never was able to find the root of the issue. When I first got the ski, it leaked alot. After replacing the rear hull drain seal it reduced the amount of water leakage.
I kind of think its my siphon... its just such a slow leak I havent put the time into fixing it.
caseville9036
BLRider
SE MI
Here's what happened to mine. While riding the hull would fill fast so I just left the bilge running till I could get it fixed.
