- Riga, Latvia
Smooth power. Ecwi helpedI just love the way these look, I wonder how it feels when you ride it
yes,the last series had removable stinger inserts that could be bored as needed. mtrhead,do you have a chart of recommended stinger sizes? have a set and thinking replacing the fp dry pipe but not sure any extra hp is to be found,maybe smoother powerband ?Smooth power. Ecwi helped
I had a set on a full limited 7700rpm
I had a set on a full 844 stroker 7900rpm
Each motor required different stinger sizes to realize best potential. Near the last set of pipes I believe Tim made the stingers to accept inserts
I’ll dig through my notesyes,the last series had removable stinger inserts that could be bored as needed. mtrhead,do you have a chart of recommended stinger sizes? have a set and thinking replacing the fp dry pipe but not sure any extra hp is to be found,maybe smoother powerband ?
