I think that's a good reading, apparently you have a 61X stator (90-95) The Yam shopmanual for a 95 Superjet gives a very wide spec of 328.5 to 401.5 ohm at 20 deg. C/68 F. I just measured a nice low mileage stator and got 351.5 ohm with a Fluke meter about 78 deg ambient,
Your ac cranking voltage is not to shabby. Is the engine cranking fast enough and did you use an analog (got a moving needle) meter? Regrettably there is one more variable: when the engine and stator gets warm, resistance might drop a lot because layers of windings punch through.
Also, an ailing stator might work with stock cdi but not with a more demanding MSD enhancer.
Don't know where you are located, maybe some one could lend you a stator to try out (rare)
