Electric jet ski has always been my dream since I got into this. There’s so many advantages and I’d spend the money to R&D one in my own ski but I don’t have a good grasp on what size motors it’s going to take to match the abilities of a 1200. Anybody an expert there? Also, you can pretty much just waterproof the motor compartment. You don’t need air. I believe water cooled electric motors/controllers are common place so we can use a pump take off for cooling.
would something like this do the job?
https://www.electricmotorsport.com/...6v-550a-liquid-cooled-motor-drive-system.html
This has like 116lb/ft peak and 26 continuous or something. I think peak torque is what would matter for instant hit needed for freestyle but would a 116lb/ft motor be able to pull like a 1200cc 2 stroke? I have no clue.
This is where reality gets kind of ugly. That motor claims 116Nm peak, which is about 85 ft. lbs. It also says max rpm is 5500. 85 ft. lbs at 5500 rpm puts you at about 90hp, and even that is likely optimistic for two reasons. One reason is marketing wank is common on stuff like this, the other reason is that we don't necessarily know that it can do the 85 ft. lbs at the max rpm. Electric motors have power curves somewhat like internal combustion motors, so most likely the torque peak is at a lower rpm, and the peak horsepower is something less than 90.
A good clue is that it says 550 amps and it says 96 volts. multiply volts times amps and you get 52,800 Watts. There are about 746 Watts per horsepower, so that's about 70 hp. Again that is probably optimistic and real world will probably be lower for a few reasons. One is that you apply 550 amps of load to the battery and there's a good change the voltage will sag a bit, and the amperage rating is likely the consumption, not the output. Due to less than 100% efficiency the output will be less than the consumption. They list 92% efficiency so if you believe that our 70hp is now down to about 63 (so stock 61x) and even that is probably optimistic, the motor is almost certainly nowhere near peak efficiency when it is at peak power.
I'm gong to say a realistic guess would be that motor would get you power that is somewhere between a stock 650 and a stock 61x.
On a more optimistic note, it says the 1 minute for the "peak" output, and to do a backflip obviously don't need anywhere near a minute, barely more than a second, so it or a similarly sized motor can probably be pushed a lot harder for 1 second than what they are claiming for 1 minute, so it might not be as bad as my rough estimate above.
On a more depressing note, it's "continuous" rating is more like 20hp-ish, which might not be enough to stay on plane. Liquid cool it and it can probably do more continuous, that is probably determined by heat.
The electric thing, while probably possible, will not be easy.
