Freestyle the lightest flywheel ever!
D-Roc
I forgot!
how much does it weigh now that it is cut. some one had some software to test flywheel dynamic forces or something. i wonder what the simulator would tell about what you did. it looks nuts. i am glad you did it though. if your 2nd guessing the durability which pretty much everyone has, put it on a 650 motor and try to pull some high rpms. i am sure someone can even donote a 6m6 motor for the cause.
Waternut
Customizing addict
Macon, GA
A program I used back in college called ANSYS could tell you the forces on the flywheel but I don't have access to that anymore or any other software that can simulate dynamic loading. Maybe someone with the tools and know how can pump out a model pretty quickly...
NW PA
I could pump out a simulation but I bet you wouldn't like it much. I might have to learn a bit about dynamic loads applied to an object. I have a computer locked at school right now running an ansys simulation dealing with sheet metal forming. 2.83ghz dual core and it had been running for 4 hours before I left it for the night.
I would have cut the reliefs to like more like triangles and tried to thin out the rim of the flywheel, triangles like these:
Waternut
Customizing addict
Macon, GA
I want to say the SJ flywheel was a little under 2 lbs. The kawi 750/800 flywheel weighs 1 lb 11.7 oz (just weighed it because I had one laying around). I can't remember which was lighter normally though because they are slightly different weights.
update: have been testing this flywheel on a ski for about 5 tanks of gas now and it works great.I installed it with a cover that I cut to expose the flywheel so I can keep an eye out for any cracks.It is running on a freestyle/rec ski so it doesnt see many high rpm runs but does see alot of jumping/sudden loading of the pump situations.IT does idle a little rougher than a stock flywheel and the idle had to be turned up a tad to compensate for the lack of rotating mass,but so far so good
Now you need to cut the cases so you can keep an eye out on the crank bearings...:clown:
Well how did that super light flywheel spool up, did you notice a gain ?
