Freestyle the micro build
UAE
this is the first time for me to build a/m hull
the plan:
motor: still now i think about how many cc i will take :smoker:
bpip
costom wwaterbox
total loss
pump 148mm 12v
Skat Trak trim
RRP Handlepole full kit
2 gal tank
this some photo about the hull
next week they will ship for the hull :Banane09::Banane09::Banane09:
ProSouth
Seriously, Don't be a dick.
kawasakis suck
do something different, run a 650. with a pipe and porting. trim, 148, total loss, pipe and waterbox. make the backflip look difficult, lol. whats the weight on these hulls? glass or carbon?
Sanoman
AbouttoKrash
NE Tenn
Looks awesome man! As a wise member on here told me a few years ago,think 5 steps ahead on anything you do.Check every threaded insert for depth.Cause if you thread too long a screw in the hull inserts,it may go right thru the hull before you know it.Mock (check) all parts and assembly's before installing.lf or when you drill holes,use masking tape where you are drilling.This way the paint or gel coat won't crack or flake around the hole.Also if you run in saltwater use Lucus Red n' Tacky grease for a lot of the bolts,screws,etc.
Sorry if you already knew this stuff,but if not,l hope it will help you!
UAE
i will use kawi pump
its glass hull his weight 40kg
thanks for the Information sanoman
by the next week i will get the hull as eric they say
thank for ryan and eric for his work
UAE
i was busy with another work but now i back to build this ski
few day go i order from brian Thrust innovations
engine 920 cc
pump 145 mm with trim
Dasa Intake Manifold
SKI BONEZ
SKI -BONEZ
Same here probably ordering one too...info and more pics would be awesome...let us know how pipe fits...witch tank u use and how it fits
skibonez
9285428519
Proformance1
Liquid Insanity
New York Crew
I worked on the micro with B pipe and one gal tank, with stock water box. No problems with those items in there, but you do have to do some work around to get everything in. Not the same as a SJ, as EME tank has to go in first, etc. Two gal should work, but it all debends which one and how you mount it etc. Take a bunch of picts and spend your time doing it correct the first time and youll be fine.
UAE
sorry its 2 gallon tank
today i see it
now i wait to get my part
which battery i should use in salt water? (Antigravity or Deka ETX-9 or another thing)?
