Its a LimitedSlip7 3.5 gal tank. Im pretty sure he makes a 5 gal also. Im def anxious to get it on the waterMuch rok love, you will not be disapointed in the ride. Whose tank is that and what size is it? I have a custom 3.5 but need more fuel....
ProBolt USAWhere did you get that hardware?!?!
Tricky built that one if I am not mistaken.Is that where this skis career began?
I'll have to check on that Rob but I believe I had to cut it off because it was glued on still really well. Thanks for the props I'm really excited to get it in the waterWow man, she looks good! Way better than when I had her!
Do you happen to still have the pole pad that was on there? If you aren't going to use it, I may take it back off your hands!
-Rob
Thanks! Hopefully it'll do it's job and still keep water out.Nice MX-style check valve on the tank. Good idea!
