N3vrSat1sfied
Military Member
- Fort Worth, TX
where you located?
where you located?
I bet you have something in your low speed jets or the low speed circuit, take the jets out and the low speed screws and blow everything out. I bet you will find something in there and also check the end of the adjustment screws I have seen a carb that they tighten the screws in to tight and broke off the tip in the carb.
