Other Thinking about making/ selling waterline restrictors
the jetworks ones are just an off-the-shelf quick-disconnect lab fitting from Colder Products that a little brass widget gets pressed into.
Depending on how / where the "plug" is mounted, it doesn't need to be a press fit...the water flow can keep it in place.
High Speed Industries
Your one stop shop for quality parts @highspeedind
I thought about offering a few different connectors but you would only need one if it uses a jet. I would offer more than one but that would drive the price up and there are way more than just 3 jets that you can run. Another way to look at it is if you were going to put in a different sized connector what's the big deal about replacing a jet while it's already out of the ski. I appreciate all of the input guys. Thanks.
