WFO Speedracer
- Alabama
I had a Seadoo sportster come to put an engine, customer supplied the engine, first off it was a single carb engine so I had to swap his single carb rotary valve cover and carb stuff for dual carb parts. I get the engine in and all hooked up and same deal nothing when you plugged the lanyard up but the programmer wouldn't recognize the MPEM .
The customer of course has no idea because he bought the boat not running and has no prior history on the boat.
I did the same thing you did plugged up a known good DESS post , nothing, checked all the fuses , nothing.
It turns out some idiot had tried and failed to bypass the DESS post on the harness side by skinning insulation off the three wires and twisting all the wires together, of course they did this on the harness side and it was buried deep down in the hull where you had to take the throttle assy. out to find it, then when I did get it cranking it wouldn't rev in gear.
I was thinking it was a bad neutral switch, nope they did the exact same BS on the neutral switch , on the harness side again , if you are going to do crap like this do it on the switch side so the part is replacable instead of jacking up a perfectly good wiring harness, some people are just straight up idiots.
