Thrust installation EZtrim
I need some help installing this easy trim set up that I just got from thrust.
There was now directions in the box and they also didn't send me my hoodie lol not a big deal..
But I got the cable through the back and up to the of the front pole. I bolted the nozzle to the pump the thing looks good from here..
Thing I'm stuck on is how do I run and mount the cable to the pump/nozzle
Is is kind of killing me because no direction i'm going to try to post some pictures so you guys can help me out thank you any help will be appreciated
Here's some more pictures any help???
Cable holder block mounts to the reduction nozzle tab, run cable through the largest whole to the top of the pulley, wrap around the pulley and back to the small hole on cable block
Thanks for the fastest response I've ever seen lol ok that's done and I'm just doing the test fit for now but what about those bolts now??
I'm guessing the ball joint end is used on the end of the steering cable, two stainless screws same length are for the nozzles? Rubber boot I have no idea lol
Yeah I'm still stuck on the bolts and ball joints because the bolts are sorter then the stock ones and with the added bracket they should have been longer... Lol idk
Stock bolt on the right
And there isn't really anything I can see y there are 2 ball joins because nothing is that tread size other then if I was to replace the stock bjoint
Unless the balljont goes here and acks like a locking bolt
And thanks for the help so far guys please keep the info rolling
The oem ball joint that goes on the end of the steering cable on both the handlepole side and steering nozzle side, would be replaced with the ball joints supplied with the trim system.
I wanna say thanks to everyone on the forum for the help of figuring this out for the first time..
Will test this tomorrow and let you guy kno how it works out
Thanks once again!!
