So it had been 7 months of owning the Tiger Craft SV-Pro and i'd like to share some findings with you all.
first off the ride plate completely shredded it's self in the first month, and when trying to get tony to help it took 3 months for even a reply.
IMG_1766 by
Jen Wells, on Flickr
IMG_1822 by
IMG_1823 by
All of the very poorly installed graphics agx designs made were all splitting by the 2nd month. I was frustrated enough with them to end up ripping all the graphics off. It's like they were not even designed to fit the pro.
When i finally got a shipment of ride plates in, all of them didn't fit at all and took a poopload of grinding to get even remotely close, the marked hole locations where you are told where to drill don't lline up AT ALL. Oh and i guess we cant even get a color matched attempt either...
here is where i start to get a little pissed off. Every Sv-Pro on the west coast of the us has super bad cracks around the pole bracket area, (ill post up the other sv's in a few, i need to get pics)
I had to reinforce the living poop out of it from the inside. Tony said 2 times he would send me a gelcoat repair kit asap... that was 2 months ago. I can assure you it's not happening...
this is one of the tubbie holes
The tray leaked so much water in that i had to seal everything up myself, the through water tubes leaked everywhere, the center bulkhead was not sealed and let water under it like crazy until i sealed that up too, even the through shaft pipe was leaking! My friend Colin's sv-pro has the same issue but even worse where the entire water through tube is loose and you could pull it right out... just sad
back to the tubbies... not sure what the hell they are thinking making them hollow, on any side impacts the entire tubbie can crush in (and does), they are full of water all the time, and the bolts have nothing to tighten against... like wtf this is not how you build a jet ski. So i came up with my own spacers permanently glued in.
this is where the engine wants to go through the floor. the mounts for the motor sit too low and the motor can just smack the bottom all day. Pete Mcafee's sv1 has a hole right through the bottom from this and i think i am getting really close.
IMG_2269 by
IMG_2331 by
Overall after having owned a tiger craft I can assure you that I do not recommend one at all. Feels like i got royally screwed. keep your SV-1's they even ride better imo lol
