Surfriding Tigercraft sv1 build
Today was the day I've been waiting for, my sv1 hull finally arrived! I figured since I didn't do a write up on my last build I should do one this time. First off I wanna give a huge thanks to Chris and Tony for making this build possible and for their support for 2017, along with Tim at TNT and Brian at thrust.
Here's some teasers before we get down to building
I'm not home to look, Does anyone know what hood seal and steering cable to use for an sv1? Hoping round nose stuff since I have that already haha
England
Did you not get a hood seal with it? Mine came with one separate to fit myself. As far as steering cable, i'm sure a regular 98-07 SJ will fit.....I've not heard otherwise.
some of my parts have started rolling in, want to thank jet maniac for the fast help. Chris rauen has been working hard getting me all the big pieces which should be coming in early next week. My limited slip tank is out of powder, just waiting on a blue cap for it.
electronics are pretty new, going to get cleaned up and tap the box for mounting. Msd, light flywheel, oem starter and bendix, and adding a jm coil because I do not trust the msd coils. I will probably do blue wire loom over the battery cables to match the coil, and water/fuel lines.
England
Put a good layer of super glue or clear nail varnish along lower part of the bottom graphics, mine peeled off on sunday. I used clear nail varnish but probably not enough im guessing.
There is a product out by 3m called edge sealer that is made for just that. It honestly has the same consistency and smell as pvc pipe glue from the hardware store. Use a small art paint brush and run along the edge.
England
Wish i'd known that before i tore my graphics up riding the other day. Chris is sorting me some new ones so i'll get some, for now mine looks pretty good just bare jel coat.
