Tighter pole
OEM pole bolt is 14mm, 9/16 is as close as you can get which is a hair bigger than 14mm. most aftermarket pole bushings are drilled out with a 9/16 bit, which is why they are loose. the XS dual bolts only work with the thin stainless crown. billet crown is too thick and XS bolts arent long enough.
A double bolt setup is the only way to get a true tight pole. A single bolt will only get it sort of tight. When using a double bolt setup you need to double nut each bolt. Lock the nuts together and use plenty of red loctite.
