- Clearwater, FL
Well I've got to install an MSD Enhancer in my ski this Friday night in Daytona so I want to go ahead and make sure I've got all of the tips/extra parts/tools that I will need for the install.
I searched through the Tech/FAQ section and didn't find anything, but I did search through a bunch of old threads on here and PWCToday and came up with a few tips/questions.
It would be great if everyone can ad some tips and answer some questions then one of the mods can put this in the Tech/FAQ Section for later use.
Ok, this is what I do know:
***Contrary to the directions you do have to hook up the red and white wires.
***Stock rev limit setting on the enhancer is 8000. Turned all the way in is 9000. Each 1/3 a turn out is a 1000RPM decrease on the rev limiter.
***You have to purchase 2 longer bolts to install the enhancer.
And these are some of my questions:
***What size bolts do I need to purchase? I'd like to pick them up ahead of time cuz I'll be doing the install at 11oclock at night.
***Whats the best way to seal the electrical box back up after you are finished with the install?(i.e. silicon, grease, etc?)
***Are the connections plug and play or do I need to bring some heat shrink butt connectors and wire cutters(This is a brand new enhancer by the way)?
***What tools do you need to do the install?
***When I installed my Girdled Head I disabled my overheat sensor by just snipping it outside of the ebox. While I'm inside the ebox I'd like to disable it from the inside. What does this entail?
Thanks:biggthumpup:
Thanks:biggthumpup:
