Tips/Tricks for lining up crank pins?
Quinc
Buy a Superjet
California
Anyone have any tips or tricks for lining up the pins on the crank bearings when installing a crank into the cases?
OCD Solutions
Rentz, GA
Pretty much the same here. Start in the center and work your way out. The center pin in the tallest so they fall in consecutively from there.
DAG
Charlotte, NC
I like the stud idea. I always placed the upper case across the center rib in a double sink so the rods can hang. Then as Boyer said rotate bearings center and work out and they snap into place.
