Freestyle Too Much Oil?
SXIPro
JM781 Big Bore
I've had the same problem with the oil dripping out the exhaust tube in the past, Turned out to be a leaking needle and seat in the carbs allowing extra gas to sit inside the water box acting like a solvent. The gas cleans all the oil and sludge from the inside of the water box and turns into a nasty mess that drips out the exhaust tube. Might be worth a few mins to check the needle and seats, even the smallest fiber, hair, spec of sand can cause them to leak. Hope this helps
I was thinking the exact same thing when I read the first post.
And as far as ratio goes. 45:1 for me. Yep, I am a rebel.
