Super Jet Too much water in waterbox help
spookyjjj
Back @ it
Billings Mt
It seems like I have do alot of high speed cleaning out before I go back to playing in the River Waves.
I have a Factory B pipe with the 1 single cooling line that has a tee in it to go to my pisser. I have a jet works flow valve on my 550 and it works great but I don't think it will work on this super jet set up. I was thinking a 1/4 plug to get less water got to the stinger. hmmmm any ideas ? ? ? I just don't want melting issues lol Thanks for any help
spookyjjj
Back @ it
Billings Mt
why wouldnt a flow control valve work on your super jet too??
well without having dual cooling and a seperate water line to the pisser I don't know that if i put it on befre the pisser to the stinger that it wouldn't melt something but if I put it on after the tee to the pisser that I don't know that it would pop off
I run a restrictor in the hose that goes to the stinger on the pipe. All I use is an egg sinker for fishing, then drill it out to 1/16", it fits in the hose nice and tight, and you can always drill it out for some more water.
spookyjjj
Back @ it
Billings Mt
Nice.... thank you for the idea!
spookyjjj
Back @ it
Billings Mt
I ran the jet work water flow restrictor and holy snapppppp. I got it dialed in and have it poping off 1/4 throttle.
I went from my water line after my FP Pipe line to a 3/8 T then right after the T I put the flow valve on to the stinger then from the T to the pisser.
