Vumad
Super Hero, with a cape!
- St. Pete, FL
My buddy had a 15' Gheenoe. It's a canoe / boat hybrid if you are unfamiliar. It's about 100# and rated for a 25HP motor.
The wooden transom is rotted and needs to be replaced. I was wondering if there are any plywood alternatives we can consider. Cost is a factor but the needed piece is only about 6"x12" so a small composite board could be purchased. I looked into Coosa, which is what I believe BOB holds use as a backing, but it's made of a reinforced foam. I was concerned about this foam, and similarly the plywood, being damaged from frequent compression and release. The motor will be removed after almost every use which will contribute to compression fatigue.
Thoughts?
Here is an image of a similar model for reference...
Thoughts?
