Trim set ups??
Jcary85
Vendor Account
Glenmoore pa
I had Raptor trim on 144 and 155 reduction nozzles, the trim ring is the same and fits both. Only the billet nozzle is 155 specific. You can install the Raptor on any 144 based Nozzle, it just needs to be tapped on the sides for the trim ring pivots.
I assume it needs a stop welded on the bottom also, no? Guess you could run without the stop idk
I have only ran stops on a couple setups and just set the cable for whatever static angle we wanted. Unless it’s an adjustable stop it just limits your options
