- Central Florida
What kind of cable would I need to run with a stock trim setup off of a sit down?
I've been asking around and know one can tell me
I have the lever and all, just need the cable and return spring
Is it possibel too purchase xs trim ring seperatly ?
Would the cheaper pro-tec option work with a blowsion tilt kit?
check your inbox, message sent.can you set me up with whole system ez flo for 144-48 for my tigercraft sv pro?
The Thrust trim cable may work since it is also a pulley trim system, but sorry not sure.do you have a trim cable that will fit the Wamiltons Superjet pulley trim system?
