- springfield mo
I'm away from home again until Saturday to check if the pump is set back but maybe I need to run a longer midshaft?? Christian says his ski has a 2" setback motorsuperjetjim says motor cant be set backI'm thinking if you set your pump back you would need to do the same to engine location to keep everything engaged (motor-mid-driveshaft)
