Truckboss jetski hauler.
I’ve only had it in sand a couple times and it can take a bit to push or pull the cart which also depends if you run two or four wheels.
The only down side to these is they don’t have a handle on the front to grab with a couple guys or yourself to pull. But I’ve made one for mine to make it work.
I also have a factory zero cart that I can use to go from the deck cradles to the water if I’m at a race. If I’m going to the lake for a day I don’t need the wheels or cart.
So if you were gonna ride surf most of the time would you recommend passing on the buggy kits and buying a normal beach cart to use instead?
That’s a hard one for me to comment on as I’ve never rode surf. But I think blowsion who runs the same setup uses a beach cart to get the skis to the water when on sand.
The wheels that turn them into buggies are nice for when your at home and want to move them around the garage.
It’s a toss up really... but I can get ya the info for the main lady up here if you did want more info.
